Maf code now I have a vac leak coming from my intake
If you're going to splice, do it proper and solder it in with shrink tube to cover it. It'll be a much more stable repair.
Thanks do you know if the 03 maf harness is different from the 97 n af connection thats my biggest concern
Sent from my SAMSUNG-SGH-I747 using Tapatalk
You'll check all three wires...one should be a ground, a reference voltage, and a signal. I can't remember if the MAF gets 12v from the battery or 5v from the computer.
Ok i'll check all connections could I use spray like battery cleaner of some sort on the wires?
Could my Tps make my maf code come? I did a test with my maf and everything is fine with my connections but my tps harness power slowly fades thru my dmm and I checked also with a 12 6v volt tester I have should I replace that harness with a new one? I have a extra tps harness laying around
