m90
rodman
So if you have a n/a 3.8 and want the m90 supercharger does this work or do you have to top swap or is that a top swap??
you have to swap everything from the heads and up, unless you buy ZZPs SSM90 kit, and if you are boosting a high compression motor it would be a good idea to do rockers or a cam at the same time to make sure it breaths enough
