Here is the long story. Motor had 250k. I was driving down the Eisenhower late night on 09/30. I was at WOT out-running a newer white Maxima. While stomping on the gas the car "blipped". Like in that GIF of the white Pontiac on the dyno. CEL starts flashing, code for misfire on 4. I limp it to parking garage, pop the hood and find the rear wires resting on manifold. Fix that. Drive home OK, but she wasn't behaving like she use to. Engine rumbled heavy under acceleration. No code on drive home. Mid week I ordered new wires. Drove it again, with knowledge of misfire on 10/06. Got to destination OK, but drove like **** on way home. Wires came that Monday 10/08. Left work early to get them in. And it wouldn't start, wouldn't start, wouldn't start. Gave it gas, it revved up, sounded awful, white smoke blasting out the tail pipe. It would only stay running when revving it. The RPMs were so erratic, reminded me of a vac leak. And that led to pulling of plugs, to compression test, and to a time of death.
I have 2 theories.
1. The misfire was causing the fuel to not ignite, it then washed down the sides of the cylinder. This happened enough times that the oil diluted, and that's that.
2. When running WOT and the car blipped, it had chipped or cracked a piston then.
