LTFT readings
Freimuth
Can anyone give me some good ranges my LTFT reading should be at?
I'm stock except having a short ram with a open cone filter. Running 93 oct gas.
213k miles
Have a bit of a stumble just cruising around you can't really see it in the RPM gauge but you can feel the car surging? When it happens.
Random CEL for a evap but I have a gas leak when I fill up so I know that issue.
I have replaced the vacuum lines and T.
MY LTFT was around -14 around 2k RPM 45mph
I have hit -22 LTFT under boost. I never go into the + side of the LTFT readings.
I'm new at this so if you need more info let me know.
youre running really rich. in the negatives means the car is trying to pull fuel and right now its maxing out what it is allowed to pull.
something is wrong.
same problem but mine stays at like -12 idle -17 to -21 under boost... looks like im gonna add an evap to my laundry list of parts i need
