    TIPS:
Lowering Spring Vibration Motor Mount Spacers
Re: Motor Mount Spacers - BACK IN STOCK!!!!
Thanks Vinnie. I will put an order in end of this week or early next week.
when i do lower im definitely coming right to this thread :D
EDIT: the link for the installation (from clubgp) is broken, atleast i cant access it...new link would be appreciated seeing as i have no idea what im dealing with
hey, thanks dude...seems sorta complicated and risky, but not too bad...be prepared to sell me a half set coming up
It really isnt that bad. Lift engine/trans, add spacers, lower engine/trans. The rest is reminding you of all the stuff that'll be in the way.
I've got plenty here. What has you asking for only a half set?
ehh...mostly because im only dropping 1-1.2 inches max...i think a half set would be better for a shorter drop right? plus, i may do a 3" DP and headers sometime in the future...so im thinking it would be easier to install them...but if you can convince me otherwise, id be happy to spend $20 more on your stuff haha
Thats the standard for most springs for our car. I would recommend getting the full set. You'll benefit from a full set because the 3/4" will compensate with that drop a lot better than 3/8" will. The DP has only been an issue for one person but I mention it so you look out for it.
As for the money side of these, I would prefer people to only buy half sets because I'd make more money, but Im not that way and I wouldn't have as good of feedback as I do for these. I only recommend the half set for a last resort to get SOMETHING in there to help out the vibrations. The full set is the right way to install these.
I'm running a full set with Headers by the way, you can make it work with a 3" DP and I have plenty of room all the way around.
I'm dropped 3"+
ok, you are a good salesman...haha, full set it is...but i currently dont know when ill be dropping, so ill contact you
Re: Motor Mount Spacers are back!
Hey Vinnie,
Have a 2000 GTX clone and just installed B&G lowering springs. Checked out all possible causes, installed new drive shafts helped, but vibration still there under load and went taking off from stop. I do have TOG headers w/ advanced tech 3" down pipe. What would you suggest to eliminate. How do I go about getting spacers that you make available? Thanks for any help. BillGTX
Hi Bill. I think these are your next logical step if you didn't have the vibration before lowering the car.
You should be able to fit a full set in there.
They are $52 shipped for the full set, 3/4" lift, or $32 for the half set, 3/8" lift. Paypal to [email protected]
I will take a full set! I have not ordered anything from a vender on here before so if you can walk me through the process that would be great! Do you use Paypal?
You can email me at [email protected]
Thanks...
