Lowered...20s?
tirerack.com allows you to order 20's so its pretty safe they work without rolling the fenders
jesus christ...
20s will not be any different than 18s or 13s for that matter unless you run a tire size that is TALLER THAN STOCK. if you keep the same overall diameter of the tire youll be fine. however, there is more than just wheel diameter that matters. wheel width, wheel offset, and tire size also affect rubbing issues.
WHAT WHEELS DO YOU WANT TO RUN AND WHAT TIRES? we need ALL of the specs to tell you anything useful. otherwise our best answer is 'maybe?'.
