Lower mounts & mounts spacers
iRideGTP
so is my lower engine mount busted or what!? where is the best place i can get solid tranny and engine mount? and while im in there i was thinking of also installing the mount spacers Vinnie sells. do u guys recommend the spacers?
yea im lowered and i have slight vibration in the front when accelerating. the mount on the tranny side looks messd up also. do AutoZone or Napa carry solid mounts?
will check out rockauto for mounts. l need mount spacers from vinnie not cradle spacers..i don't even think vinnie sells cradle spacers. thanks though
cradle spacers do not come from vinnie and they move the cradle DOWN to LOWER the motor/trans.
engine/trans mount spacers move the engine UP.
You can make your own pretty easy. I used some 1/4" scrap steel from work, cut it out into 1" squares, and drilled something like a 1/2" hole in each of them, and I had my spacers.
you could always just use washers, too.
you wouldn't be the first person to stack washers to make a spacer. and you wouldn't be the last, either.
yall are starting to convince me on stacking washers. its 3/4" of height to add, right? ..atleast that's what i think the spacers add
