bradmeyers79
Hi All
I am having a problem with my headlights that I could use some help with. Currently my headlights don't turn on either with the automatic system nor using the switch. The daytime running lights work, the parking lights come on, and the high beams work. But, the low beams won't come on. For some time now the low beams have intermittently have switched on and off at night when on the auto switch. Now they have stopped working all together. I have checked all of the fuses and all are good. I have also switched out the ignition switch wiring harness and that didn't fix the problem. I believe that the issue is the light switch wiring harness. Has any seen this before? Any thoughts on if the switch wiring harness could be the problem or any other thoughts as to what the issue could be?
Thanks in advance for any help.
Brad
Brad
