Low Oil Pressure
bobeebob
Ok im gonna try and make this as short as possible.
-swapped cams and everything ok
-did some burnouts and on way home oil light came on
-cold motor 35 psi at idle and 5 at hot idle (checked with mechanical gauge)
What the question is, is if i can band aide the problem by replacing rod bearings and switching to a heavier oil?
right now i use Liqui Moly 5w-30 synthetic
And yes i did change oil before starting engine (im thinking i should've done it twice)
Any input is appreciated :)
I packed that thing full of assembly lube and also primed motor prior to start.
Ill replace it as a last resort since i don't feel like taking everything apart :/
Bob, I am not here to piss in your cornflakes....the reality is.. that motor is coming out and doing bearings often doesn't go well in these motors. They aren't a SBC 350 and they are durable as all hell...right up until you let the smoke out.
You let the smoke out.
spun cam bearing --> blocked oil feed holes ----> oil starvation
new cam on old bearings = risky
stop driving it immediately and rebuild
And i just finished rebuilding the trans:th_bangheadonwall: ....looks like ill be looking for shortblock to rebuild, thanks for all the help guys
Bob..having been in a similar situation ... the best inspirational advice I can offer is.. "the bolts shouldn't fight." Each time I told myself that one.
You're right..it doesn't really inspire does it?
Just realized i never replied haha.
Turned out to be a spun cam bearing which i thought was rare for 3800's in the states??
Oh well but thanks for all the help guys
