Looking for some help.
Bluemagic
Ok little brother car is having problems. Recently did an manifold job and everything went down hill from there.
So here we are. Problems are that plugs are wet with gas, car is misfiring badly on all cylinders. Huge vac leak. I think it's reading 0.4 at idle. So we are trying to find out where to start.
Also four of the injectors pulses aren't reading on my torque app. I'm going to screenshot it and post it here. Thanks guys
So what the hell is going on. Trying to help him out :)
Sounds like plasti dip might of gotten into the motor and fudge everything up..
Sorry I just had to lol
double check the plug wires. look for a broken vac line. you just touched them all so good chance one broke. spray carb cleaner at the lines when its at idle. rpms will jump if you hit a broken line.
make sure the injector plugs are clean.
If you have a huge vacuum leak, the computer will dump more fuel in. So.find the vac leak and then see. Also. Torque app only reads 2 sets of injector pulses. Do you have an ses light on?
if the plug wires are wrong they are not burning the gas right. it will pop out the intake too when wires are on wrong. or just run like real crap.
if it sounds like its got a nice cam installed now. 500 rpm surge rupp rup rupp sounds, thats a huge vac leak. if its super charged check the fat line to the evap. that one likes to break. as well as the T's/
cant hurt to double check the wires too.
Ok changed vacuum lines and we have 18 vacuum at idle so now we are going to change the plugs and tackle the p0068 Throttle Position Correlation and pending fault code P0101MAP/MAF - Throttle Position Correlation.*code. Any idea where to start?
