I can't get this injector off
Lol working on it, What's the best stuff to use to clean up this mess ?Jesus degrease that bay!
pull it straight up. twist it a few times that may loosen it up some. certainly looks like its oiled up enough.
id change the valve cover gaskets while you got it apart.
ive used a lot of the parts store sold cleaners, engine foamy brite works good, but i found that crc engine degreaser works just as well if not better with out the smell afterwards.
what ever you get, buy 2 cans, you'll need it. put the car on ramps, spray underneath first, get the tranny from the pass side wheel well, and from in between the engine and tranny, oil pan , up the sides of the block to the headers. you get the picture. lol
then spray the top side down. get a old paint brush to scrub any thick areas.
i say buy 2 cans, because 1 is never enough. sucks when you run out. it goes fast.
as far as hosing it off, hose everything. the only thing to cover or remove is a open cone filter if you have one. take it off, then use a bag and a rubber band to cover the TB opening.
not sure what year you got there, but if the maf is in the TB take it out, then use throttle body cleaner, or carb cleaner will work.
dont spray the maf with anything but maf cleaner.
for paint use a high heat paint, like caliper paint.
Just like any other part. Make sure to clean it as best as you could, tape up where you don't want paint to go. Primer, then paint with something like engine enamel.
The rad was leaking so I bought a new one today along with a new condenser, I'm still gonna flush it tho, this gunk is everywhere![]()
