Lets see them guages !!!!!!!!
Newest setup for me.
Thanks Doug, Here's a couple build pic's to give you a idea on how I did the bezel. Some of the materials used were a ten dollar junk yard bezel, wurth two part plastic apoxy, Sem plastic adhesion promotor, Sem texture spray and Sem GM med gray paint. Feel free to ask any questions. Evan
You find out little things about pods when you build them. Like...having gauges on your dash in the sun.. not the ideal place. The aeroforce would have to cool to be visible. After that, I used a sunshade.
Just running through this again, and noticed the comment about the sun and heat effecting the gauges mainly the Aero force is this true also on the HUD Pod for our GPs? Cause that was the route I wanted to go with cause I have a GPS where the pillar would go and I dont really want to move it from there? If it makes a big difference ill go with pillar pod but just wanted to make sure?
I've noticed with mine that if it gets really hot the gauge will wash out almost. It's programmed to turn off if it's too hot. Though it only happens if I've been parked in the sun for quite awhile.
