Led tail lights
I have the black ones
I.think smoked anything looks horrible, because no one ever takes the time to clear coat and polish afterwards. Looks like a 5 year old tinted them...
LED bulbs in stock housings are ok, but the Spyder LED's are 10x brighter. I went with the red one's.....
Park lights:
Brake lights:
Post some pictures once you get them installed if you don't mind, I have a black car also and I was considering the red smoked ones also. Just so darn expensive but I love the look of 'em.
Ok the LEDs came in but I'm having major fitment issues there the spyder ones idk what's going on there's a huge gap underneath them and the pin doesn't slide all the way in on the corner any input is appreciated also did you seal yours?
I have a larger gap at the bottom also. I painted any exposed silver paint with black, so the eye doesn't pick up on it; it hasn't bothered me, and I can be picky about that kind if thing.
The pins can be a little off. If you can't gently force them in, you will have to bore some of the holes a little bit.
Here is a crappy pic showing the gap vs stock.....
Ok as long as its not irregular i can deal might paint mine black also did you seal your lights because there are huge gaps on top of the lens and also the trim doesn't sit under the trunk lid like the stock ones did
.....also did you seal your lights because there are huge gaps on top of the lens and also the trim doesn't sit under the trunk lid like the stock ones did
I did not seal mine as they looked fine. Two years of Wet-Coast weather and no moisture inside.
I have some just dont know how to post pictures on here I tried through photobucket but no luck I can send you some via email or phone just pm me
its sooooo easy right click on the bottom of the picture and then hit copy image then click on the box in here and paste image
