Led tag lights.
bziggy58
Anyone replace there factory license plate lights with led bulbs? I am just curious as to the best place to buy them. I see a few online but I never expected them to be $9 a piece lol. Is worth replacing them?
I buy all mine from superbrightleds. Its a great site to order from and cheap prices
Sent from my pager using Morse code. ... .. ... ....
im looking on there sight and they have a lot of options for the 194s. What one did you get, how many leds on the buld? are you satisfied with the light output?
Hold on let me look...I gotta pull the sight up
dont do LED bulbs.. Do LED strips....
Case in point.
STOCK
LED strip
Yes I agree led strips are the way to go...if I hadn't already done mine with a bulb I would re do it with a strip!!
Running no license plate lights is a ticket in most communities, and the cops WILL pull you over for just that alone.
how does a led strip work with the tag light and other lights in the interior? aren't the strips bigger than a bulb, therefore not fit in the normal bulb socket?
yes they are bigger but all you have to do is pull the socket out...with battery disconnected. then cut the wires and splice them together with the wires from the light strips
Yes I'll post it when I get off work for u. I actually have a couple strips in my car right now for the turn signal mod I'm doing
