LED Halos
2 switches for each halo? i was thinking of using a single pull double throw (SPDT) switch. so it would be like:
red
off
white
and then theres 3 terminals on the switch, common top and bottom, so i could run either power or ground (either way it does what it needs to do). so lets say i go power to the switch and then go to the top of it for red power and then bottom for the white power
you just need a dpdt relay (double pole double throw) one side for amber when the relay kick for the turn signal, the other side for the white connected to the running light.
Gotcha. Figure that for making it into the turn signal.
red
off
white
I'll look for one of those switches soon.
if that was at me i meant for having 2 halo colors, and not use them as blinkers lol
i understood yours iroc,
i'm just trying to offer css any info i can for his project
Thanks. Since I am down at college it will be awhile before I get the relay because I can get them for free at my dad's work. And for the switch I aint sure if home depot carries those
Umm. RadioShack? They have tons of ****. As for multiple colors, just get a switch with multiple positions and wire them up for common feed and switched ground. It's always better to switch the ground because it's easier to diagnose a short, should one occur.
wow i need to go learn stuff before i look into ordering! awesome site! just wish i had a furrther expanded led knowlegde. time to learn! :)
