SnowDrift
I have a need to replace the snout seal. How do I remove the pulley without pressing the whole shaft out? Is there a puller made just for this? I plan to remove the snout, anyhow, to reseal, just to be sure it's not oil from the housing, also. I am seeing oil on the intake manifold, but have also seen some on the hood. The leak started a couple weeks after I reinstalled the snout after replacing the bearings.
Years back, I posted this on the original seal leaking, but I'm not sure I got an answer on how to remove the pulley and seal, only.
http://www.grandprixforums.net/threads/52262-Leaking-oil-at-pulley-end-on-S-C?highlight=snout+seal
