tu8i1o7
Well i just passed my last NC vehicle inspection until I move back up north. So.. it's time to do a few things that I couldn't do before. Starting with ripping out the EGR. I figure since I'm in there I might as well install me new LC-1 for tuning. Before I start I got a few questions pertaining to the wiring. First off I want to simulate the narrowband. Can i use the connector from the old sensor and connect the signal wire AND the ground? Second, I haven't checked it out yet, but for the heater wires, is one of them a 12v and the other a ground? If so, can i use these wires for the LC-1 power and heater ground. I am going to hook up the wb through the EGR, should I use the signal ground for the analog ground. If this is all completely wrong, let me know I'm just trying to determine the best way to hook this thing up.
The car is an 05 comp g, and i'm using hp tuners. Any help with the wiring would be appreciated. If I get some good answers I'm thinking I might do a write up if all goes well. I've been searching, but haven't seen a real easy to follow step by step write up. So I figure I might help some out as well.
