Lateral arms
Le Patriote
Hi guy's. I just noticed something. Why all lateral arms on W-Body are bent ?
Seriously, i have 3 w-body and all have the lateral arms bent. When i take a look on the web, all w-body have arm bent . It is normal ? They are pre-bent from GM? Or my 3 car have been towed ?
If my arms are bent, not too much, and the alignement is done without problem, do i need to change the arms or not ?
Thanks !
replace em anyways get bmr best ones out there imo. and im prety sure they arent supposed to be bent htey are just super weak
Maybe lol.
After I read this again, because I skim alot. Lateral arms should not be bent ever, if they are the preson before you or you yourself have either hit something or had a bad tow truck driver do the damage.
Trailing arms are the stamped steel cheap piles of junk parts that bend easy.
Maybe lol.
I have GMPP package , so the sway bar and trailing arms.
For the lateral arms, damnn the BMR products seem to be very nice, but alot pricey !!! :th_lipssealed1:
I will take a look for the wbodystore lateral arms ( 239 for the 4 lateral arms) , or, the dorman one.
HT Motorsports rear trailing arms and alignment (lateral) arms... 1/2 the cost and just as good IMHO as the BMR's.
