pontiackid
About to order my Yella Terra's. Spent the last while working on finishing up some unfinished work the machineshop left for me to do... :th_shakinghead1:
Anyways the heads, valves and everything is setup for a .6 lift to run the XPZ and a bit more. Pedistal cut and everything. Any reason I should consider running a 1.7 Yella Terra over a 1.6? I have heard of guys with the smaller cams like the VS cam doing it but, recent;y heard of another member running a higher lift rocker with a custom cam grind similar to the XPZ I'm using.
Thoughts?
Thoughts?
