l67 zzp hvtb on l36
Grimsin
So I got a l67 throttle body spacer and a zzp l67 hvtb for super cheap and i read i can use the tb spacer to attatch the tb on my l36. I wanna throw it on with some er rockers then get retuned.
My issue is the throttlebody spacer only came with 1 gasket... I can use the gasket to seal the tb spacer to the tb.
But what would be the best way to seal this UIM to the tb spacer? Would copper rtv suffice?
Suggestions would be greatly appreciated.
Anyone..somebody??lol
Would buying a l67 tb gasket work? Or a l36 one? Reuse the one i have perhaps?
I would just use regular rtv. Its just a throttlebody, nothing to worry about especially if you blocked coolant ports. But either way rtv will be fine.
It's been a long time since I put an L67 tb on my GT, but I remember filling the cavities on the rear in with red silicone, pretty sure I used the L36 gasket once I got it filled in and cured up. If the tb spacer is smooth, you should have no problems with it sealing up to the intake with the L36 gasket.
