GTP89
So i finally have time to do my engine swap just about ready with everything but remembered that when i put my heads on i took off my rockers to put the pushrods in since i forgot to do so on one side, the others went in when i put on the head. My question is do i need to worry about anything like adjusting anything as if i was checking for lifter preload or any adjusting or is that only when installing aftermarket cams and lifters and pushrods? Everything is stock but have no idea if when i crank it over if something will happen like a valve not closing right or something.
Before i do the engine swap i just want to make sure on this. If the weather is good in the next week or two i should be putting it in.
Engine as of now.
Engine as of now.
