    TIPS:
L67 97-03 Plug Wire Guide
Burbman
I am removing the 10mm "racing" wires in favor of 8mm taylor wires. These were 10mm Taylor wires with custom MSD ends that have a crappy, sloppy fit onto the plugs and it's time for them to go. Think the PO spent some coin on these but I think the sloppy plug connections may be causing the random misfire codes I am seeing.
There is a wire guide that bolts to the top of the pulley end of the SC snout just under the sight guard, mine is missing. Anybody parting out or making a JY trip, let me know and will make it worth your while.
Just use some zip ties you don't even really need anything the wires aren't long enough to go in harms way
Sent from my SM-G920V using Tapatalk
I have my old stock plug wires if you need some I just changed them because they were orginal and I put bigger ones on they work fine about 100,000 miles on them
universal MSD 8.8mm bendable boot HEI sets. 80$ and you get to make em to length and have two full length spares, with spare terminals so you can shorten them to replace a damaged wire. makes diagnosing a misfire easy.
still have yet to use one of the spares even though they've been installed/removed about 700 times with the damned thing blowing trannies left and right like it was a pornstar
Like this:
It's on Bonnevilles...and a few of the other large body cars. I think 2003 SSEi had the part number stored. Might be worth shooting him a pm.
Back when I was looking, I spent weeks Googling the part number. Last I knew it was no longer available anywhere new. I think at this point your only option is a junkyard. All three I found came off Buick Ultra's.
That's where I'm at...I thought maybe somebody parting out an L67 or somebody who saw one in a JY would want to make some quick cash.
