plus i wont have to worry bout warpage or leaks from the upper intake because its aluminum.
I believe the balance is the same, so you should be fine.the L26 didn't come with a fly wheel, can i use the one from my L36?
I don't see why not. It's the same block.the l26 didnt come with a power steering pump, can I use my L36 setup?
No. Your 98 is going to have EV1 connectors. I know the L32 uses EV6 connectors, and I think the L26 does, but I'm not sure. Even if they don't, the L36 switched to Multec 2 connectors around 2000, so it's not going to be EV1. Why not just use your stock injectors?also am I going to be able to plug the L26 injectors right into my 98 GT injector harness?
So would I just be able to take out the injectors and put mine in their place, using the same fuel rail or would I have to use my fuel rail as well?
well duh, but im just asking so i know what has to come off of the engine thats in the car now
