colindunn
code for a knock sensor came up. replaced it. engine had very bad lag and ran like crap when you gave it gas. replaced the knock sensor with a new one. had to drain all the coolant and stuff too. still had the same problem. a day later i replaced my plug wires and noticed a bunch of rust on one of the contacts on the coil pack. i cleaned it off and it ran fine again. then 2 days later my knock sensor code comes back and my car runs like crap again but not nearly as bad. i can go WOT with no problem but the throttle response isnt there and acts as if it was no power under light throttle compared to before.
weird problem!! what could it be? something else throwing the knock sensor code or is it a faulty knock sensor?
