Got some 20% Tint all around...and 4300K HID Headlights/5000K Fog Lights...went out for some pics today after the car's first detail this year
Steps taken...
Hand wash/dry with...
Megs Car Wash
Turtle Wax Liquid Clay Bar
Megs Medium Cut Cleaner
Megs Fine Cut Cleaner
Megs Yellow #26 Show Car Glaze as a finisher...
Turtle Wax Tire Shine applied to a towel and wiped down tires/wheel wells/waxed wheels with the #26 finisher as well.
Here were some pics...and then a little start-up, rev, acceleration...and yeah; it was in gravel apparently on the right side...or you can just say I'm a badass...cuz I know I be one in a 16 second car.
Mods as of to date performance wise are: K&N Intake, CED 2.4 Intake Manifold Swap, Polished Throttle Body, and Magnaflow Touring Catback Exhaust System w/ Factory SS/SC 3" Angled Polished Tip...
recirc helps keep the compressor moving during shifts as well.
Something you'd only care about if the car was a manual though.
How much boost is the thing running?
Does it have that typical recirc valve?
I ask because apparently the 710N valve is better suited to running around 18-20 PSI compared to the lesser versions.
Audi B5 A4 Quattro 1.8T > Search > Diverter Valve > ES#581 710N Diverter Valve - Priced Each - 06A145710N
I can't find a clean cut answer. The way the MAF/MAP dictate/translate...It's anywhere from 18-20psi from what I'm seeing. I'd like to just plug in a damn aeroforce and read it. It's really strange...you can feel it too when full bore into the throttle, it's got SO much more in it, but just watching the tach...you can watch it stall, go another 500~rpm's....stall...go a few thousand...stall for a split second...le lame.
I wonder though, I'll have to look...this is what I was looking at for it: Forge Motorsport | Alloy Fabrication
It did however get tinted and some HID's in it...I'll take pics soon![]()
The gains are hard to measure because the Regal adjusts its boost by the amount of airflow the MAF sensor is seeing. So as you add mods the car sees the added airflow and reduces your boost to bring the power back down
No.
It's like that because you can't even measure them correctly on the dyno.
Yay, computers.
Per ZZP:
