Keep my Resonator or not
rij1
My resonator is making noise like metal chattering and dont know if I should replace it with another one or a glass pack or just remove it and weld a pipe in it's place. I have two dynomax super turbo mufflers on it already.
nawwww my exhaust on the DOHC is the same im running now. both sound great. 2.5" high flow cat, 2.5" x 18" magnaflow muffler, 18" glass pack and dual tips.
which resonator are we talking about. the one under the car or IIRC there is one on the passanger side
Im also wondering about my resinator and weather or not i should be going to something different.no cat on the car still has all other stock piping except for two 4' supertrapps running 8 discs now.Im going to try 12 plates each side as it still feels a little trapped at higher rpms.i would just like to make the note a little deeper without sacrificing to much power.
make sure that you tell the installer you dont want a b.s. patch and if they use any pieces to put it together that you dont want them to use smaller diameter pipe than whats on there already.
