Hi all,
I just bought a 2000 Grand Prix GTP w/92k, blk on blk looks good inside and out probably repainted. Well it was about 10 degrees when I bought it and evidently didn't check it out very good. The car seems to run good, has power, good brakes/steering. Here's what I have found since buying the car one week ago:
Bad power window motor - replaced
ABS/TCS comes on started intermittant now most of the time
washer pump not working - no sound when button is pressed & leaks
Both floorpans soaked with water - trying to get dry - hoping sunroof wasn't closed completly caused this - I knew motor needed help to close when I bought it.
Poor Gas Mileage showing 11 mpg
Temp guage only goes up to 180-190 if that
Valve covers leaking - thay cleaned the floor in the garage b4 i got there
Heat works but not very good
I'm afraid to try the AC
I know a lot of this is minor easy to fix stuff but it just seems to be one thing after another. Of course the seller told me everthing worked - no problems man. fxxxxxg Liar.
I need to start with the water leak and tune up
The car is a 2dr and looks really sharp I paid 5,200
Your thought -Advice
Thanks
Thanks
