Found a small issue with the cylinder head...
2020-02-20_06-25-05 by
Ben Stryker, on Flickr
There's a coolant passage that runs right in between the valve seats, so all the time and effort I put into the head was wasted.
But I found a damn good deal, and I'm pretty stoked about it.
IMG_20200227_135709057 by
It's an improved casting... It's much thicker in between the valve seats for better heat dissipation, plus the intake and exhaust ports are improved over the stock casting.
IMG_20200227_135821715 by
And I got a couple extra bits with the head:
All new intake/exhaust studs
A set of dowel pins for in between the head and the block
A set of dowel pins for in between the timing cover and the block
And finally, a new oil pump gasket that ended up being free.
I needed new studs, because I destroyed some of the old ones pulling them out of the old head.
I needed the new dowel pins because half of them were already missing when I pulled the engine apart.
I needed the new gasket, because I had to pull the oil pump back off and the old gasket didn't survive.
I've been busy dealing with a metric f*ck-ton of **** lately, and haven't had time to do anything to the truck... But I'm going to try and make some progress this weekend. Hopefully.
