Still on the stock pump. I need to put a voltage regulator on the gauges as they like to drop and it starts to give false readings. If I have the radio up with a bass heavy song the fuel pressure gauge will drop about 6 psi. I did have a couple of runs where I watched the fuel pressure drop about 6 psi at the top of first and second, but not at the track as I routed the sending unit wiring too close and parallel to the ignition wires and every time I would get into boost the gauge would just drop out. It happened on the way to the track and every time I ran but it too me a couple of days to catch it. At the track it was pig rich. I still need to lean it out, just haven't had the time, and need to get new tires. Every track I have had the same tires the last 3 years. I am sure I could get to solid mid 13's if I had better tires and the tune is better, they are still 225/55-17's.
I still have a 5% OD dampener and a 3.1" to put on, a nitrous kit, a set of 1.8/1.85 rockers an some 2.2:1 ratio rockers, but I am not going to use those unless I port a set of heads. I plan on going through the suspension later this year. I just replaced the strut mounts and bearings a few weeks ago and another failed Motor Mount. I made some molds as well and need to cast some solid poly mounts but after Harvey hit and flooded the house and cars it put us pretty far behind.
Jeff
Jeff
