It's alive with a burning passion
AaroGaming
I bought this '89 Camaro on February 14th, this vehicle was parked across the street from my Grandma in 2011, and hadn't run for a few years.
305 V8 5.0l paired to a 700R4 automatic trans.
So why wait to work on it right? By the 18th Liz (the girlfriend) and I moved it over to my Grandma's house and left it for the night.
On the 19th (Friday), after work, I installed the hood supports, put the new battery in, and moved the car into the garage where Bill (auto body tech and friend as well as the new owner of the '97 Camaro RS w/ 3800 series I sold) helped me get the battery hooked in correctly, and we organized through the interior. I stayed the night there after Bill and Liz both left for the night.
On the 20th (Saturday) I got up early and got some PB Blaster, Sea-foam, 93 octane fuel, WD-40, and a breaker bar with a 5/8" socket from O'Reilly's and I got back, sprayed down the pulleys and accessories as to make it easier for the crank to spin. After breakfast with mom, grandma, and the girlfriend, I returned to working on the car. I pushed it out into the driveway, jacked it up and Liz returned with a wild Devon (random friend that loves cars) who ended up helping me pull all the spark plugs and spray some hyper-lubricant into the cylinders to help the piston rings from shredding when I tried to get it to crank.
Once we lubricated the cylinders I got the engine to crank using the breaker bar and I spun it a good 3 rotations before we tried cranking it via ignition.
Turn the key anddddd nothing, occasionally not even the fuel pump. Previous owner replaced the starter and water pump, and we can hear the fuel pump turn on so what's the deal? We started diagnosing it and we ended up tearing into the steering column, and after messing with the ignition cylinder we got it to crank, and not only did it crank, IT FIRED UP. IT SOUNDED GOOOOD. So from there we packed up all the tools, put them away and took it nice and slow down the road, brakes worked, transmission went through gears as it should, and the tires were rolling smoothly. It was running so well in fact that we drove it all the way to O'Reilly in Algonac from Anchor Bay Drive!
It turns out the car has a few pinholes rusted into the fuel line in the engine bay, and it started dying on the way there yet never actually died, but it did sound deprived of air/fuel even after it had parked. After deciding it must need a little throttle body adjustment the air cleaner/casing was removed and we started it up.
The car backfired out of the throttle body and set the fuel system on fire! But this isn't the end of the car! I turned it off immediately, Edward (friend who works at O'Reilly's) runs into the store and get the extinguisher in record time, putting out the fire after only seconds! Granted we had to sweep dry-chem off the parking lot for a while, nothing was really damaged. In fact the dry-chem actually helped me locate the fuel line that had leaked, and the part is on order. A fire extinguisher was put in the Camaro and after sitting overnight it was driven back to my house, now left to wait for the replacement fuel line.
And that's the story of how I got a 1989 Camaro running and driving over a weekend and only spending $745.62
before ordering the new fuel line @ $158.72 (stainless steel costed extra but not rusting is gonna be worth it).
As of the time of this post it needs:
*Fuel lines replaced
*Brakes bled
*Oil changed
*Driver and passenger window regulators
*Door seals
*Door hanging pins (because these big heavy doors tend to sag)
*Speedometer
*Dash lights
*New interior lights
And could really use:
*Clay bar
*Grill replacement
*Hatch lift supports
*Hatch sun shade fabric
*Automatic seat belt mechanism rebuilt
*Venom 400 rewired
*Wires tucket/hidden/managed
*Rear seat delete
*Radio replaced
*Repainted interior components
I'll add more tomorrow.
my buddy had an '89 IROC Z-28, and it had the TPI 350. looks like a fun project. any plans for an engine swap?
Perhaps down the road a bit, for now I'm just gonna get it cleaned up. Rerun a lot of the wires, hide and tuck wires, replace any rusty lines with stainless steel, get some of the rust replaced, get it undercoated, get a disc brake rear axle, etc.
If it runs for now then I have no real reason to change my engine, so until I have to I'm going to get it rolling better and get it safer.
I plan on putting a roll bar in there for now, deleting the rear seat, replacing the radio and just general restoration.
Sent from my SM-G900V using Tapatalk
I think you made an awesome score with your bucks. That is dirt cheap V8 transportation and a good story to boot. Stay the course, you're headed in the right direction and its great to have some help. Enjoy the project, Aero.
the 305 is better than all the v6 camaro's of the '80's, but not even close to a GTP. Making the car safe to drive is a far better option. have fun with it before you start dumping thousands into engine work.
The 305 isn't far behind a gtp to start with, once I fix the fuel issue it even has more torque.
the 350 TPI was the most powerful Camaro engine of the '80's and made like 240 hp. the differences between it and even the 350 TBI were noticeable. if it was me, I would try and swap in a 5.3 from a half ton, or just do a carb'd 350 small block.
nothing from the 80's was good, it needs mods, and then its still a 305. but it should handle pretty good for what it is.
I'm going to get the 305 running properly, replace the suspension, , subfrane connectors, roll bars, seat harnesses, rear seat delete, reduce rotational weight, then upgrade drivetrain
I plan on swapping the rear axle anyways to get disc brake rears, I was going to swap the gear, and at some point I'll upgrade the engine. I've been thinking 350 or 427, but I'll take what I can get more availably. Somehow I keep getting things handed to me for super cheap. Hell I got a jetski/wave-runner for $1 and this camaro that runs and drives at less than $800
