Issue after intercooler install, car revs high then drops way low
P0107 manifold absolute pressure sensor low,
P0102 nice or volume air flow a circuit low,
P 1107 manifold absolute pressure sensor circuit intermittent low voltage.
The car will start up then die right after so I do not really have time to check for leaks.
My vac line is routed from the lim to fpr where it has a T, then from there to my map sensor. Yes my fpr is on the other side of the fuel rail. Any problems there? I have checked the line a few times and see no cracks.
You might have to do a smoke test to find the leak, or just spray around with starter fluid. When the engine revs up you know you found the leak.
instead of spraying around with starter fluid I use a propane blow torch and am just careful not to ignite the flame.
We all agree it's a leak so I'm going to take the ic out of the equation, just want to make sure it's not a problem with the modified lim.
