Too lean is never good, if anything a little rich is best. Running lean and open throttle is a good way to chip pistons. Just take it easy.
if your running lean enough to throw a code...then you are not just a little lean you are VERY lean...be careful!
If you know your maf is bad, unplug it and run off the pcm tables. At first the car will run like crap until it learns the tables. Running off the tables will most likely make you a little rich and safe.
If you are getting a lean bank code, then the pcm is telling you based off the O2's that it's adding more fuel than it's allowed w/o pushing a code. It's not necessarily lean.
You bet you can. One of the first things in the FSM for maf testing is to unplug it. :th_thumbsup-wink:
But if your car is like many other 3800 cars they are not coded at all to use the ve tables when the maf is working then it becomes pointless. But if you one of the few with it coded into the pcm then your good to go.
pretty much, but its still good to run it. your car will just be in better shape all the time if it can run independent of it.
Ok thanks. Hey bio, wanna grab that pic from the lounge and do some circling for me?![]()
Isn't that 1 of the Mod's Jobs?Nobody post where they should anymore. Also the tuning section is kinda a dead zone .
