Slick2500
Active member
Yup checked it out it will work. You could wire up everything just like he did too.Even though I have the monsoon sound system, it'll still work?
Forgive my ignorance, but will the aluminum foil interfere with the wireless communication side of it?
Also, if you encase it in plastic wrap or other items, will it cool properly? I'm pretty sure the cooling is passive, not sure if there is a problem with putting what is essentially insulation around it.
Good luck with the project! Just trying to give you a few things to consider.
Yes you could, but it would look stupid and then how would access the radio?Couldn't you just install a bluetooth capable headunit behind the iPad?
