JJ91284
In the picture, you can see the groove that my fingure catches when I run my finger over it. Is that fairly common, how should I proceed.
If you look inside the case, you can see a few areas where there are some ridges that were created or also sharp edges from the casting process. Should I just take some emory cloth and scotch brite and go over those areas to smooth it out. I would make sure to get all the metal debris cleaned out to prevent contamination.
On another note, in the manual it says to remove the final drive gear from the transaxle by lifting. Is there any reason why my 97 is giving me problems in trying to remove it. Or does it just need some postive reinforcement with a block of wood and a hammer.
Oh yeah one more thing, What is the perpose of the thermo element, and why does it say to remove it in the manual?
