SgtMarshal
Active member
I did what you said earlier today when I was talking with Scotty, I haven't had a chance to test it out and see how it works. I will be able to in the morning. I used the shop vac and used a couple different sizes of vacuum line to neck down a line small enough to go into the hole. I am curious if this is the problem I have been having.
I also forgot to install the o ring that goes around the pcv valve and I thought that was the problem, but I had the same symptoms after installing an o ring. that is when I noticed the rtv at the bottom of the pcv in the supercharger.
