Intake vlv. cleaning with S/C
LouF
I went ahead and (semi) blockheadedly sucked up SeaFoam through the brake vacuum booster line on My '05 GTP to do carbon build-up cleaning. I think it's OK to do, but not quite sure. First time for any cleaning for it; 121,000 mi. The engine did seem to run smoother. I'd guess changing the s/c oil would be smart, but i just did it about a month ago, so I'm likely to blow it off (using synthetic 5W30 now). Open to comments...
Update: It is definitely smoother and is noticeably more responsive from off-idle; practically like a new car. The throttle body should have already been reasonably clean. I let it sip through a whole bottle; then sat ~1 hr.
TB cleaning probably did most of it.
120k~ ain't bad.
It needs blower oil, though. 5W-30 will eventually seep and breakdown much quicker unless you're changing it every oil change as well.
