TheYanz
Hey. I've been visiting this site for months more so kinda searching for stuff & never really was compelled to post anything. I pretty much found all my answers from reading everyone else's stuff (ESP ABOUT High LTFT's = Vac Leaks/ Bad tune 90% of the time
Lol). I'm kinda curious about the intake setup. Anyone ever try to rig a strong sturdy, say 3.5", tube & zip tie it (REALLY WELL) to the underside of the driver's fender to kinda create a Ram Air effect? I've toyed with this idea a few times. Would that have any gains over a FWI where the filter is buried in there but not directly in the line of any incoming high velocity air at high highway speeds? Please nobody freak out on me! Yes, of course, there'd be some sort of filtering going on. Perhaps even cutting the tube at one point higher up in the fender, slipping some of that material from those crappy stock drop in filters, recoonecting the tube, then taping it all up really well with that heat resistant aluminum tape. I saw the ZZP dyno test or whatever with the diff setups/ lengths/ filters/ angles of kits. But that wasn't a road test with any incoming air at very high velocities, was it? Stand still Dyno, no? Perhaps I'm not understanding what exactly happens @ WOT. Wouldn't what I'm suggesting just ram a ton more air up the tube, through the throttle body, & into the SC?
No good? Would it perhaps lean out the mixture like crazy? Maybe the 24-25 PSI (+8-11 added PSI) more than enough for the SC to suck in a sufficient amount of air to compress?
