Intake help
x4 on making your own
although if you absolutely HAVE to blow a bunch of money on something you dont need to, i recommend the wizaired intake from zzperformance.com
does making one out of pipe and putting a good filter on the end really perform better then the stock one that is basically the same thing? im not bashing on the homemade or the ones that places make em im just interested because if they really help ill just have to make my own
yea actually that does sound alot better to make your own one that you know will work better. and also u may save alot more money
Saving money and function is the real reason behind it. People get on here and ask wtf when we bash them after they buy a K&N Intake...$350 for the same thing that WORKS BETTER for $50 ish? You tell me ;)
yea i get it actually so i guess im gonna make mine, is there anything you suggest i buy specialy for it?
You have to worry about heat dont you? If you sick a open filter in your car your just sucking in hot air! Thats so bad for your car Bad MPG and even worse timing retard! Get one that comes with a box to block dout the heat! If you can afford it get the Wizaired Cold Air Induction System
thats wut anyplace would give you if you bought one for alot of money. just this way your making your own and saving alot of money
you get better MPG with a hot air intake...unless you think phsyics dont apply to the world anymore.
If you suck hot air into your car your maf will tell it to retard the timing making it worse? Do you not have a maf on your cars?
