fri3dchick3n
Well I have found out that I have the following that arent working properly and need to be replaced:
Inner Tie Rod Ends
How hard would it be to change them out myself. I believe I wil need a special tool that will make it a lot easier.
Which brand do you recommend to replace them with? Is there a write up for this job?
Should I just replace the whole Rack and Pinion?
Spindle Rod
I have also found that the Left Rear rod is pretty bent up, dont see how it got so bad but needs to be gone asap.
Found one on GM Parts Direct for $75 with shipping. Not too bad I guess. Any other brands you guys might prefer?
I checked it out, and it looks like it might a straight forward replacement?
Strut Assemblies
Left Rear one is leaking and the coil spring hitting something on the body of the car I guess. I want to replace the two rear ones here soon and the front ones a little bit later on.
I was maybe thinking GMPP ones. I know this will be a lot of a personal opinion, but which ones have you guys had a nice experience with? Or which ones should I stay away from?
Any tips on these things? It would be nice to get this all fixed here soon.
Thanks in advance for your help once again
Inner Tie Rod Ends
Spindle Rod
Strut Assemblies
