do i NEEEED the special tool?
I'm quoting this from the GM Service Manual for W-Bodies.... (I would post the entire thing, but all the instructions are for replacement with the rack out of the car and really wouldn't help much).you are able to rent the special tools needed at any local parts store.
1. pull tire off
2. take outter tie rod end off
3. cut metal tie holding inner boot on.
4. take inner boot off
5. place special tool on flat spots off inner tie rod end..and turn counter clockwise..and pull out.
6. put locktite on new inner threads..before you put on.
then it is opposite of removal....takes about 30min in your driveway.
Important
Threads must be clean prior to LOCTITE® application. Check LOCTITE® (or equivalent) container for expiration date. Use only enough LOCTITE® to evenly coat threads.
If male rack and female inner tie rod (1) do not apply LOCTITE®.
Tighten the inner tie rod to 100 N·m (74 lb ft).
