injector removal
Charged97
i seen some oil seepage round my middle injector guessing its my seal /oring how hard is it to remove and replace this part on my 97
If its motor oil there, that may not be the injector, in fact, its most likely not. Its more likely that you have a leaking valve cover.
Yeah it's most likely an intake gasket. The fuel rail is pretty easy to remove, 4 nuts the just lift up. Caution: If your a smoker give it up while doing this as some fuel spillage should be expected. Make sure to replace all 12 of the injector o-rings. Use a light oil to lube them up when reinstalling them into the head. Good luck!!!
