Speedo is plug and play ^ have one in my gtp. For the front you would need the front end, both front panels and rocker panels.
Actually i would like to know this as well. I wouldnt mind swapping out my DIC for one with tire pressure levels and gforce menu...hmmm.
you will be faster....very much faster. i wanna eventually do the body swap. and you can that ls4 all you want...then detonate more expensive trannys instead of just building the 3800 and detonating less expensive trannys
Well i already have TPMS but it doesnt show me the Level of each tire...did i mis read somethin? In the GXP does it tell you the level of each tire (i.e. RF is 35psi and LF is 33 psi) or is it just normalsystems won't work, you need to controlers for them.....not too mention you do NOT want to pay for the stems to have individual tire pressures...it isn't cheap.
mine tells me each tire :0)
buy a tire pressure gauge thingy, and walk around to each tire and see what it reads. Its just that easy, amazing i know right.This is the one i want...LOL I wanna know each tire
Son, I am disappoint.plus, I don't care much for the body of the GXP either
