Inet size
I believe stock sc inlet is around 72mm (2.83") (a match to the zzp ported tb) . I am in the process of porting one to ~ 75-76mm (2.95") and zzp now ports their inlet to 78mm (3.07") to match their billet tb.
Stock tb blade is 69mm (2.71")
Thanks for the replies, so that means if I buy the ZZP Hv tb, the tb inlet will match the Sc inlet. Buying the Hv tb and having hone the sc inlet isn't something I want to do.
Edit: Got an answer from ZZP, it does match.
