in need of vacuum line pics
Don't mean to sound like I'm asking a stupid question but what does "wont start" mean?
spin and spin with absolutely no fire at all
spin and try to fire but won't officially start
spin, fire, then chug and die
Is everything hooked up? Did you take the coil pack bracket off? I ask because it has a ground attached to it that might have broken or did not get attached back.
it will fire right up really strong rev to 2k rpm then die out n no question is a stupid one unless it requires a stupid answer. and no I didnt take the coils off
no mods and I found 2 plugs that are not in but I cant find the other sides ill send a pic in a sec but pics would be great right around the battery is what im talking about
I'd be willing to bet it's a mystery plug that several people have on their cars. They are for other factory options your car may not have. But without seeing the pic, it's my best guess.
I am still leaning toward a vacuum leak. Did you check your EGR tube? It's the accordion piece going from your lower intake manifold to your EGR. It is mounted under your throttle body. It has to be removed or at least moved when you do a LIM job. I'd assume the piece is fairly fragile, nature of the beast.
