buickman104
Once in a while (becoming more frequent) when I shut the engine off the ignition will not allow me to click the ignition switch to the off position as if I had turned the engine off while still in drive, not park. I would turn the ignition switch to run and play with the shifter rowing through gears try again and try again until finally the ignition switch would allow me to click it to OFF.
Eventually I realized that it had nothing to do with the transmission gear select because when the ignition acted up I would be able to turn it to OFF by just playing back and forth with my ignition and not touching the shifter at all. My car has well over 200k and is city driven so I guess something is worn and needs to be replaced. Any ideas or suggestions as to what needs to be replaced (aside from the whole car
