Ignition Coils
Can I swap a series 2 for a series 3 n/a I locked up my series 2 a friend crashed his series3 so I hope it's a mach made in heaven pls
Yes, the block is same. Will have to swap stuff. Definitely have to swap intake.
How did you lock it up? Sure you didn't lose intake gaskets or upper intake? Very common and hydro locks the motor.
Yes you can run LIM but its aluminum and you need adapter for the throttle body. I believe you have to do something for PCV. .
Is that the only thing I'll have to change lim I hear the plastic ones that I have go bad fast the aluminum ones are big upgrade
