ignition coil pack swap
BeezyPlatt
i have a 06 gxp and i need to change the coil pack on cylinder 7. Does anybody have a diagram layout of the cylinder placement? & Does anybody know if theres any specific instructions on how to change it?
Cylinders should start on teh driver side front as 1, 2 is passenger side front. Going in that order, the back one on the driverside should be #7
Your coils should be mounted on top of the valve cover IIRC and therefore it's easy..I think it's unplug the harness to pack and pack from plug wire, then it's likely two 10mm bolts.
In case i'm wrong.. please know..I totally shot all that from the hip.
a 8 cylinder should be
closest to the bumper, (reading from the pass side of car to the driver side) 1-3-5-7
rear of engine 2-4-6-8
your coils should be right atop the spark plugs, mounted on the valve covers.
Not forsure but check the repair manual on gpona. I've seen it one there before
Sent from my pager using Morse code. ... .. ... ....
OK so if its FWD you said it correctly, Bill described a longitudinal set up like a RWD. I wasn't sure if the GXP was FWD or RWD, I remembered reading that the Holden that GM built in Australia was RWD.
Here is a picture I have in my gallery of ls4 information. If it helps any
That's the image I got off ls1tech a while back. Is that not correct
Yes I knew that lol. Just the way pic was. But if u rotate it clockwise then it would be right. That's the way I pictured it
LOL I assumed "front" meant front of car. Yes, this diagram is correct. Front of motor is where the belts are.
Hahaha... why the heck would I think the way I did... See, it's lucky I put the disclaimer on it. Turn what I said clockwise and it'll make sense.
My bad. I'll clarify that better next time :banghead:
