T
TDCRacing
Guest
Car surges at idle only. Doesent seem to be a real pattern with this but i do notice it a lot more when the engine is cold rather than warm. This just started not long ago and cant remember doing anything to my tune before it started. The engine will surge in small amounts lets say from maybe 600-1000 then will slowly climb to like 600-1500 then eventually just kill. starts right back up and pretty mucch does the same thing.
Give it a little gas and hold it it is fine. Also when it's doing it it is only in neatural. As soon as i put it in drive or reverse it stops.Another thing i noticed was when driving and comming to a stop the rpms surge up maybe around 400 or 500 rpm's and the car jumps foward a little and then everything is fine. Going to check the iac now. And just for kicks i adjusted the idle to 850 across the board so i could rule that out. Trims are out of wack but have been way worse with no problems. Working on that also.
Ideas?
Mod list in sig
Ideas?
Mod list in sig
