IC fuel rails?
the aeromotive rails don't fit.
If you are running h body / l36 front mount, they won't clear the l36 mount, you'd have to clearance some of the structural webbing and I think it would fail.
The brackets barely clear the blower flange bosses on the front rail
The brackets in the rear do not clear the blower flange boss near the alternator, at all. If the rail were to seat completely in the rear, it looks like it would touch the boss, and there would be no way for the map sensor bracket to mount under it.
a 90* orb fitting near the alternator puts the an outlet basically directly behind the snout, so you'd have to go to a different fitting or something...
its just a lot of headaches... I'll let you know what I do to get them to work...
I have the new version of the ZZP logs and love the.
BTW, ive ran the "cut up stocker" mod for my fuel lines and it looks soooo tacky and i wasn very comfortable running them...
Ive also had the ones in your original post and they were decent for my budget but I would HIGHLY recommend logs... I lost some knock, no leaks to this day, and they look so much more bad ass than anything else...
Ignore the retarded piping.... that will be redone soon enough.
Thats a 2.25" core.
