IC Boost Pressure
footballplaya3k
I think I'm having a leak issue with my garleak gasket, just want to see what you guys think. I have a Gen V with a 3.4" pulley on a WBS 2.25" IC. I'm only seeing high 7's through most of the rpm range and it will peak usually right under 10. Seems a lil low to me, thoughts?
what are your ltft's? If they are 16.4 at idle or basically at all times ten you have a leak. Im goign through that right now and cant seal my core for **** no matter if i use garleak or oem gaskets. Im still thinking im leaking from somewhere else.
Nope.
Boost pressure is a sign of restriction (related to flow)
Since our motors both use the same camshaft, rockers, heads(flow numbers should be nearly identical), headers, intercooler core... I'd say they flow pretty similarly.
Just can't run as much timing because the compression gets in the way.
Nope.
Yeah idk why I thought boost would be effected by your compression.
